Are you using the switch at the door, or your key fob? If fob, check the batteries. If switch, you need to get into the wiring of the switch and see what's going on. That sounds very typical of a fuse, or the switch itself died.
When using the key fob where is that signal being sent? The fact that neither the key fob, the actual door switch nor the numerical pad on the drivers door has any effect on locking or unlocking.
The key fob sends the signal to an antenna somewhere (I am not sure where). But if none of that stuff works, it certainly sounds like a fuse. Have you pulled the manual out and hunted down the fuses that could cause this? That should be your starting point.
If memory serves me right the antenna for the key fob is inside the roof. BTM
One other thing you may want to check is your battery (ies). If it/they are dying, it could cause this also. How old are they/it? (Do you have a diesel, or gas?)
I’ve got the complete manual from AllDataDIY which is a great resource.
However posting here always gets me pointed in the right direction and then I can use the manual to look at wiring diagrams, fuse locations and stuff. Heck I thought these things were vacuum so you can see you got me heading the right way lol.
Batteries are very good. It’s a diesel. I’m out of town for a couple days but will check the fuse and if that’s ok will disconnect the batteries to give the computers a chance to reset.
Again thanks. Glad you guys take the time to help out.
