Stop lamp switch
Old 06-22-2018, 03:47 PM
Bri Heather's Avatar
Bri Heather
Bri Heather is offline
Stop lamp switch
first off thanks for everyones help so far.
can anyone decipher the wires coming out of the blocks on a 1960 f100, i bought a laminated wiring diagram but around 60% of the colors are different to mine.
i am trying to wire up a stop lamp switch but cant seem to find the correct wires!!
black/red and brown wires, not sure where they go!
bit of a mess here.
Old 06-22-2018, 05:38 PM
matthewq4b's Avatar
matthewq4b
matthewq4b is offline
Am I seeing that right you have chunk of plywood as the adapter to fit the newer style master cylinder ?
Not to be derisive but sure as the hell hope you are not planning on driving it like that.
Old 06-23-2018, 02:32 AM
Bri Heather
nope, well spotted. just a template for the 1/4" steel plate.
Old 06-23-2018, 06:40 AM
Bri Heather
truck is not being driven yet, wood adaptor is to use as the template for the steel one, just hooked it all up to fit master cylinder and bleed system. on the live wire bit, the pic below is what was wired up when the old cylinder was on and i had brake lights, ive checked the pressure switch on the new cylinder and all good there. all the lights and indicators work but no matter how i configure the live to the wires "i think are the right ones" i can get brake lights. the previous guy done a lot of chopping to run a modern style alternator so the loom will be replaced but not yet.
the pic below is how the old master cylinder was wired up and i had brake lights!!
Old 06-23-2018, 04:44 PM
Bri Heather
All sorted now, the original wire had snapped in the loom, must have happened whilst being moved about.
The bit i dont understand is why my wires from FORD sockets are different from all the wiring diagrams ive seen for a 1960 truck!! did ford just use any colors they wanted?
milkstake
06-05-2017 07:55 PM
wjstarck
02-02-2016 04:41 PM
Tennessee Toy
01-29-2011 11:04 PM
Brainard 66
05-19-2009 11:20 AM
mar36
03-08-2004 11:18 PM
Quick Reply: Stop lamp switch
