Rebuilt Carb and engien floods frequently
Hi all, I rebuilt my 2100 carburetor and now my 68 f250 camper special floods more every time I drive it. I'm not the most mechanically inclined but maybe it has something to do with the position of the carb float? When I did the rebuild I made sure to measure the space from the top of the float to the correct space but maybe it didn't work? Heck, for all I know it could be as simple as adjusting one of the screws? HELP ME!
Pull the air horn off with truck on level ground.
The float height sets the fuel height. The bench setting is just that, have to check the fuel height after installation. ASSUMING the needle & seat was replaced together as a set, AND assuming there's no grit or crud blocking same, and ASSUMING the fuel pump output is in spec, what you need to do is adjust the float down so the fuel height level in the bowl is correct. On Holley carbies it is easy. Not so much with other carburetors.
Use a quarter as your height gage. From the top of the machined portion of the carburetor, the fuel level in the bowl should just touch the quarter. 29/32" if you're keeping score. If you're REALLY careful, you can idle the engine with the air horn off and observe the fuel height. Keep a fire extinguisher readily available for your truck anytime you work the fuel system. Otherwise let it idle for a few minutes, shut down, and pull the air horn to check.
Remove the float altogether to bend the tab is safest, just bend tab a little at a time. The fuel height in the bowl is what is important, not the float height #. Some people (why??) think the engine must be idling to adjust the float height.
Ok, yes the needle and seat were replaced together and no there is no grit or crud, the thing looked brand new when I was done cleaning it. I'm not sure about the fuel pump but what do you mean about using a quarter as my gauge? So the fuel should be a quarters (25 cent piece) height below the machined part of the carb after taking the top part off? Am I understanding you correctly?
Yes, I steal this picture off the internet from time to time. It should get you in the ballpark anyway. It's from 4 wheeler magazine.
http://www.fourwheeler.com/how-to/en.../photo-04.html
I had the same problem. Especially when I stopped for a short time. Checked float level several times....same problem. Changed needle and seat 2-3 times ...same thing. Then I tried bending the float tab differently and it worked! Apparently the method I was using to bend the float and tab to get the correct height was not allowing the needle to seat properly. Try adjusting the float level with the proper bending procedures per directions and see if that helps. When all else fails, read the directions.
Originally Posted by tcherry19
I printed out a pretty detailed carb rebuild step by step guide and did the measurement on the float dry but there was definitely too much gas in the chamber when I checked it just now.
If the fuel level in the bowl is too low, that isn't any good either. Engine will starve at high speed, or even driving around curves. Somebody once wrote "if you could only make one carb adjustment, float height would be the most important" and that's probably true.
redneck_davis
11-30-2017 02:36 PM
Blutox
03-01-2008 12:51 PM
MHull
11-05-2007 09:21 PM
teds74ford
21
04-20-2006 10:54 PM
