1952 F3 windshield install question
Old 06-22-2018, 03:21 AM
Tul01's Avatar
Tul01
Tul01 is offline
Hi guys I got around to installing the windshield and rear windows using the soap and rope technique and it went reasonably well but I have a couple questions. Firstly I didn’t used any acoustic sealant as the tube I bought said it was a fast setup and I didn’t want it to interfere if i ran into difficulty as this was my first attempt with a window install. Did the rear window first and it was predictably tight. Moved on to the front windshield and it was almost too easy and left some serious gaps underneath as if the glass might be too small? Both came from LMC. I was thinking of just filling the gaps with the acoustic sealant now tyat it is in as i am concerned that the volume to fill the gaps would be a huge risk to smear easily and be a big mess if i pull the windshield and reinstall it over the acoustic sealant?
Old 06-22-2018, 03:25 AM
Tul01's Avatar
Tul01
Tul01 is offline
I apologize as this is a double post as i first posted it in my build thread but it never got any response so i thought i would give it its own topic. Thanks.
One more pic:
Old 06-22-2018, 01:33 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
I would just pull the rubber away(like your pic) and caulk from the outside. Non hardening caulk like butyl rubber is what you want
Old 06-22-2018, 01:45 PM
Tul01's Avatar
Tul01
Tul01 is offline
Thanks tinman, The stuff i have is non-hardening, from a window installer. I just didn’t want to smear it every where on my first try. I was thinking it should be good to go just by backfilling from the outside. Appreciate the second opinion.
Brent
Old 06-23-2018, 05:53 AM
5851a's Avatar
5851a
5851a is offline
those gaps make it look like the glass was cut to small.
pogeybaitF350
2017+ Super Duty
08-26-2018 11:49 AM
johnfin1
12-20-2017 12:03 PM
tbm3fan
08-28-2009 08:06 PM
bucks77ford
02-05-2008 07:21 PM
mark914
13
11-23-2005 12:43 PM
Quick Reply: 1952 F3 windshield install question
