EGT / Pyro picture location request
Here is my hole (...waits for laughter to slow...).
I was under there for a while seeing what angle of approach seemed best. Settled on what you guys see below. I will tap it here once my Edge EGT sensor kit shows. Used the frame and a brake line to keep the drill square. I started with a 1/8" pilot hole so the R or Q bit would center on it. Not sure of the letter, but one of the two. Apparently an 11/32" will also work. BUT, do your own research on that one.
Be sure to wear goggles, safety glasses alone are insufficient. Dewalt makes a great set for about $10-12, also great for working with refrigerants for A/C.
Mine is a simple, old Insight CS. Works fine once I updated the software and firmware. Amazing how few parameters this 7.3 has to my old 6.4. I think I picked this unit up when the CS2 and CTS2 hit the market as everyone wanted the latest and greatest.
How how can one of these rigs actually get at WOT with stock injectors? I have full exhaust and open intake. No boost leaks. Billet turbo wheel if that matters at all.
