Crew cab removal from frame
A hoist isn't the same thing as a two post lift with arms. Presumably, he has a single attachment point above the cab to winch it up, like a gantry system.
.....and perhaps some further clarification by the OP regarding the type of equipment he is working with, along with a more detailed description of the vehicle application will enable us to better assist with his request.
I have a hoist, not a 2 post car lift to remove that cab. A hoist is a device that could also be called a chainfall (mine are air)
if i had a 2 post car lift that was open i would lift it off from the rockers but its not available.
so once again, lets explore my options with a hoist or chainfall. I was thinking of lifting it through the roof as shown above but was worried it might distort something. I can use one chainfall/hoist on the rad saddle section and the second on the back through the door openings. Has anyone tried this with a super duty crew cab?
with regard to the post about using bottle jacks, would the 4x4s or whatever i used go from rocker to rocker?
The new cab was loaded onto my trailer with a fork lift and i need to rig it somehow to get it off the trailer also.
https://www.ford-trucks.com/forums/1...y-project.html
Unfortunately, almost 1,000 posts in the thread, but lots of info on dealing with a body off of the frame in it somewhere.
When I picked up a new cab for my 04 I built a dolly using 2 pallets and attached casters to it. By using my engine hoist I was able to place it on the dolly and then wheeled it off the trailer. I also purchsed a piece of 3/4" plywood to place on the trailers ramps. When I changed the cabs I was fortunate enough to have a friend with a 2 post lift.
Ok! So in case anyome cares i got the cab off the trailer! I had a single cab OBS and the crew super duty back to back, the regular cab OBS i just put a sling through the roof and off it came
the crew cab for my current super duty project i had to put a sling through the back roof with wood brace as shown above, and then a sling and shackles on the front two body mount brackets in the engine compartment. Came off great! Camera on phone wouldnt take that pic though no memory!
im now ready to start my super duty project in a month or so and the OBS f150/dana 44 solid axle/351w build after
Tmarkh
08-17-2017 08:25 PM
tn.jed
04-25-2010 08:27 PM
Rarerat
18
08-19-2009 09:17 PM
macman85602
03-24-2008 01:25 AM
oldblue31
06-10-2004 09:10 PM
