Wheel Spacers
Wheel Spacers
Does anybody know where I can find wheel spacers with a centerbore specific for the Aerostar? I’m running a set of non-Ford wheels and the offset is close but needs to be pushed out approximately 10mm. Any help with this would be much appreciated! Many spacers are available but I haven’t been able to locate anything with a specific centerbore. Hoping to find something with a better fit than the generic pieces you find at the local auto parts store.
I was concerned with the center bore of the Explorer wheels I got for my Aerostar; the Explorer wheels have slightly bigger bore, so they don't get hub-centered on the Aerostar hubs. But they were centered just fine by the lug nuts; they run very smoothly with no vibrations at all. So find yourself some beefy lug nuts. I got the stock Explorer lug nuts which held the wheels perfectly centered, and provided the attachment points for the stock hub caps:
https://photos.app.goo.gl/GbNRuVD7UyFADdKr8
I was concerned about the stud length. The aluminum wheel flange is a bit thicker than the stock steel wheels, so the studs didn't stick through as far. So when I tightened the nuts on them, they did not have as many threads showing as stock. I was thinking seriously about installing longer studs, especially if I experienced any wheel wobble on turns. But a year later while I was rotating the tires, I saw no distress on any of the studs or nuts, so I stayed with the originals.
i just bought these, and mounted them, works fine (Y)
https://www.ebay.com/itm/2-Pcs-Wheel...53.m2749.l2648
kennyfzj80
01-31-2018 06:33 PM
1984Fordf250
02-27-2014 10:34 PM
EZLariat
2004 - 2008 F150
07-16-2004 08:09 PM
