400 Intake
400 Intake
1978 F-250 400 4-speed 1 ton axles
Need to freshen up an old 400 to put in my '78 F-250. I have an old 650 lying around and have been doing some research if it would be a good fit. I've found that it would be cheaper to put a 4 barrel intake and the 650 on it than to buy a 2 barrel. So to the point, I've seen a lot of people recommending the Edelbrock Performer 400, and I was going to go with that, but being budget minded I saw a Weiand 8010 intake for quite a bit cheaper on eBay and was wondering if anyone has had any experience with it? And if it would be Worth it over the Performer 400.
Thanks, Justin
Thanks, Justin
Search is your friend,
https://www.ford-trucks.com/forums/1...anna-know.html
https://www.ford-trucks.com/forums/1...shoot-out.html
https://www.ford-trucks.com/forums/1...ntake-wtf.html
https://www.ford-trucks.com/forums/1...b-upgrade.html
https://www.ford-trucks.com/forums/1...-351-400m.html
https://www.ford-trucks.com/forums/9...e-quick-s.html
https://www.ford-trucks.com/forums/1...-400-ford.html
just some of the threads I found when I typed "intake" into the search bar.
With that out of the way, I prefer the new China made Weiand. Its smoother and more rounded in the runners during transitions and has shown to produce a bit moretop end power than the Edelbrock performer. The Performer has more squared off runners and more drastic squared off transitions from plenum to runners. It also has smaller runners and produces a bit more low end torque. Either will work, so go with what's cheapest. The SP2P is a great manifold for a stock engine that's looking for some low end boost, but it will reduce top end drasticly above 4000rpm, many don't consider it do too the extremely small runners. On a modified engine you have pretty much one of two choices, Weiand or Edelbrock, both are good. The above threads will shed some more light on the issue.
on
IMHO forget about the Offenhauser. It is usually the poorest performing intake compared to whatever is or was out there for the particular engine. I have one for smallblock chevy and I cannot believe how twisted a path it is to get to the rear two cylinders. Read Steve Dulcich's intake manifold for the Mopar 383, it is available online for free. Out of a great number of intakes the Dual-Port ranks at or near the bottom. IIRC it also requires more jetting and I suspect fuel puddling is part of the problem. It is also not a dual plane intake. It is like two single plane intakes perched on top of each other.
R.
R.
Thanks, Justin
Thanks, Justin
I'll stick with my USA built Performer, thanks. There is a story by Tim Meyer, I think, about which intake to use and from what I remember he said they weren't much different in output. But I can't find it. And, when Weiand made the switch of manufacturing facilities, people stood in line to buy the USA Weiands. This is why I don't believe the Chinese Weiand is that much better, if at all, than the Performer. I believe it's true that either of them are worlds better than a stock two barrel intake.
A two barrel carb flow is measured at twice the pressure drop as the four barrel. This means that the 500cfm figure must be divided by the square root of two, 1.414, to get equivalent air flow ratings. That Holley 500 would be rated at 355 cfm max.
R.
R.
the second link I posted.
The Edelbrock is better for torque down low and the Weiand produces better top end. The exact numbers are in the thread above.
I'll stick with my USA built Performer, thanks. There is a story by Tim Meyer, I think, about which intake to use and from what I remember he said they weren't much different in output. But I can't find it. And, when Weiand made the switch of manufacturing facilities, people stood in line to buy the USA Weiands. This is why I don't believe the Chinese Weiand is that much better, if at all, than the Performer. I believe it's true that either of them are worlds better than a stock two barrel intake..
