best torque intake manifold carb combo 351w 94 f150
94 roller long block from mabbco. bought the rv camshaft, kb flat tops, stock heads. 94 f150 with zf5 for towing. what is the best torque intake? and carb to go with it. mabbco says that i dont need more than 650cfm.
35-255-5, what intake carb combo do you recommend? builder tells me final compression ratio will be 9.7:1
I recommend Edelbrock as a brand for the intake & carb. No idea what models produce best torque at what RPM. I would see what model(s) produce the most torque at your preferred towing RPM range.
Yes, I think my chances are a little better than 50/50. I saved $1200 compared to promar. supposed to get a better than stock cam (for a carb), keith black flat tops, dual row timing chain, oil adapter, hard rod bolts, high volume oil pump, and shipping for $2400. I called paypal and asked about return policy. If there is any debris it goes back. i think paypal is better than the credit card companies. They are very busy. And I only seen one bad review for this year.lol three weeks before it gets here.
this truck was bought new for a line boss who towed equipment. it is rated 10,000 lbs bumper factory capacity. i have installed an axle hitch and been at 15000 gvw many times between arkansas and florida. now this post is for advice. if you have advice for me, please post it.
No.. an F150 has a maximum 10k COMBINED towing rating at most.. that's total weight of truck and trailer and even then that was with a auto trans, manual trucks were always rated lower. Post up a picture of the calibration decal on the drivers door pillar.
dont want to go fast. i need to tow 3 yards of clay from Alabama to Florida with this truck. Brand new Wranglers, 11" disks in front and brakes on one trailer axle.Geico
