Fuel Wheels Center Cap Doesn't Fit...
Has anyone else running Fuel wheels had this issue? I had new wheels and tires put on yesterday. Went with Fuel Podium 20x9 +1 offset wheels. The center caps fit fine on the front axle, but aren't deep enough for the rear, maybe a 1/2" too short. Dealer has no idea if Fuel makes a center cap that fits the longer rear axle.
Anyone have a fix, or know if Fuel makes a deeper center cap?
Rear hub, no cap.
Rear center cap too short.
Front center cap fits fine.
Rear hub, no cap.
What did the company say when you asked them this product-specific question?
http://www.fueloffroad.com/contact.cfm
The problem is that ford mid year changed from sterling 10.2 axles to Dana m275 which has a bigger hub assembly. This isn’t for just 350’s. My f250 is the same way on my bmf wheels. Bmf (sota) has changed their hub diameter on the newer wheels since. Looks like fuels are the same way.
Both are great axles, btw. No issues with either of them.
Kind of. It wasn’t a mid year change, it is intentional for the build. Ford specs the Sterling 10.5 on 250s without the HD tow package, and the Dana M275 on the HD tow and 350 SRW. The hub diameter is exactly the same between the two. The axle shaft stub sticks out just under an inch further on the M275 when compared to the 10.5.
This may not be the same issue with the fuel wheels. Hope I don’t confuse anyone.
I had the same problem with my Raceline wheels. The company I purchased from was very good and got the right ones for me. Mine needed to be an inch longer. The first call resulted in an extension. It did not work either. The second call got me the correct one.
Good luck, I hope they make it right for you.
The super duty hubs are “hub-centric”. They rely on a closely machined inner hub diameter to center the wheels on the axle, and use two piece lug nuts with a flat face. Both front and rear axles use the same hub centric diameter, thus you can move wheels front to back. The Dana 60s are the same from 250 to 350, thus requiring the rear hub diameters to be the same. If your replacement wheels are also hub centric, then absolutely do not take a Dremel to the inner diameter.
Many replacement wheels are “lug-centric” and use tapered lug nuts to center the wheel. In that case, the inner diameter of the wheel is not as critical, because it doesn’t ride on the hub.
Nottom line way to tell — two piece flat lug nuts=hub centric, one piece tapered/cone shaped lug nuts=lug centric.
