Erupting Oil Filter
Erupting Oil Filter
Decided to make a new thread, problem specific.
My motor wants to run but as soon as I build up and oil pressure the oil blasts through the gasket and pours down the sides of the reservoir. I've carefully reset the gasket 6 times now, torqued that lid down, crank the motor and boom we're pouring oil everywhere. Am I using the correct parts?? Missing a part? Gasket is garbage? Replace with something else??
Guidance please!
Alex
Guidance please!
Alex
Every filter I get usually has two gaskets, one that fits perfect in the groove on the lid and one that seems too large. When you take the lid off, the gasket should be so tight that it stays in the lid. Hard to tell but that gasket looks wrong and is probably bunching up causing a gap
JB
JB
I would get a new filter with a new gasket, install the gasket in the lid before you install it to make sure it’s the right one and get the lid bolt tight. If it still erupts sounds like you have a sludge clog or an improper gasket on the return flow back into the block. My bet would be the wrong lid gasket though.
JB
JB
JB
JB
Is it possible to just buy the gasket or do I need a new filter with it?
This one? Oreillys Filter
