What did i do wrong replaced pins and still door sags to much to close
Replaced pins and bushings because doors saged and wouldn't you know it still sags. what can i do to lift the door handle side of door so it will close without having to lift it a half inch or better all the time? Thanx for reading and any input
The driver's door on my F-350 sagged in a similar fashion after the wind caught it...sprung something slightly. To fix, I cut slots in large fender washers and slid them between the loosened bottom hinge and door. I played around with the number of washers until I got it right. It took about 3/16" thickness to achieve correct alignment of body line...I tweaked the striker bolt a bit, too. Works perfectly now.
88grandmarquis
09-20-2003 09:45 PM
