Is a steel bed really the best?
What's the Best 3/4-Ton Work Truck for 2017? - PickupTrucks.com News
The point of this post is to bring to light the Chevy portion of the testing of the four trucks. On the Chevy, the front wall of the bed literally caved in under the weight of the sand. I believe the Ford bed is aluminum.
Personally I think it was a mistake for Ford to put an Aluminum bed on a truck. I realize their goal was to reduce the weight but for those using their trucks for hauling rocks, sand, bricks etc: I believe a steel bed would hold up better and longer. I doubt there are many prospective buyers that are going to buy a truck with a bed that's beat up. IMHO
Actually I don't think anybody cares anymore what the bed is made of. For personal use, most people utilize a bed liner. Over the years I have, because I would haul my own sand and gravel for projects that I had around the house. The deal is it makes no difference if you have a liner or not, after heavy use, they will all be scratched and dented. Now for contractor I believe its a different story. I have a friend that owns a small construction company. He has 6 1/2 ton's and 1 3/4 ton. They use the 1/2 tons most of the time to haul, lumber, tools etc. When a job requires hauling of demo'd material or sand, gravel or brick/block, he has a large dual axle dump trailer. It is pulled by the 3/4 ton truck. His chevy 2500 bed was nicer looking than my old 3/4 truck.
The number one reason that I now have a Ford is for the Aluminum body. I probably would not have moved away from Ram if the Ford was still being made if steel.
Those of us living in the salt belt areas of the county welcome Ford's attempt at the Aluminum body with the hopes that it somehow will hold up better to the road salt and other chemicals that the steel bodies have. I simply am unable to wear a truck out around here before it rusts away to nothing. So, I'll gladly welcome the Aluminum in the hopes that somehow it will be better long term.
The number on reason that I now have a Ford is for the Aluminum body. I probably would not have moved away from Ram if the Ford was still being made if steel.
So am I. You could have loaded my Rams with feathers over their lifetime and there still would be nothing left of them. My point is that the amount of a beating that a bed can take long term is pointless if the bed rots away and is unusable.
Not to be argumentative but isn't part of maintaining a truck keeping the bed clean and repaint if and when the need arises? At least that's what we used to do when it needed it. We didn't just drive it until it fell apart. That's why we have the various types of bed liners.
Regardless if it`s steel or aluminum, without some kind of protection and if it`s used in the way that you mentioned, both will be dented, scratched, and just overall beaten up.
The beds on all my trucks have rusted from underneath, not above. Liner/no liner, or the type of liner makes no difference. Should I pull the bed and repaint the underneath periodically? How about the frame, the fuel tank, the brake lines, the trans cooler lines, the PS lines, the radiator support, the axle housing itself, brake components, the cab, the bumpers? You folks who suggest that cleaning is the answer - in the most sincere way, I have no doubt - have no idea what salt belt rust is and what it does to a vehicle.
The next GM boondoggle will be the best... carbon fiber. Yeah, right. CF isn't meant to show its strength in the type of application GM intends to use it for. After a year or three of warranty calls and disgruntled customers, it will fade away, and then you'll see GM praise their all new aluminum bed as "the best".
What manufacturers need to do is make the bed floor independently replaceable, regardless of weight. I don't see the bed sides inside rotting, but the floors and at the tailgate.
