I was cleaning out the old storage room at work and found a 5gal bucket of "NEW" Rotella 15w-40 Conventional most of the lettering on the bucket was gone due to some chemicals falling over the bucket but there was a date tag on the bottom of the bucket that read "00-15-10 im assuming thats the date on the bucket and contents with in.
So with the assumption that it is in fact and 18 year old batch would you run it? If I do decide on using it its most likely going to be used one of the equipment at work.
I wouldnt run it in anything I cared about. Instead, I'd mix it with some paint thinner and paint my utility trailer decks with it
As long as it was sealed I'd think it is okay. Call blackstone and ask them, they'd tell you for sure. They could even test it for you. Still be cheaper then buying new.
Ask the manufacturer. I spoke with powerservice about the diesel additive I use from them. They said try to use it within a year of opening and if sealed it was good almost indefinitely. I was asking since the winter stuff was on sale locally last spring. After speaking to them I stocked up.
Not saying they are the same but you may be surprised.
Even water has an expiration date I would think the cleaning additives would dissolve like soap going weak
A lot of that is just complete BS, there is an expiration for salt - even though it's already millions of years old, for some reason in a year or two it'll be past the "best by" date lol
I believe that once oil has a few cycles on it the carbon effect takes over from there on the age .
So even a few cycles on burnt oil the time is ticking .
Excellent point on salt there and my bet on an expiration date would be the FDA. They seem to need an expiration date on everything we consume.
