Towing with the 6.2L
Just bought our '17 F250 with the 6.2L V8/ 3.73 and was wondering if anyone is towing trailers that are 8000 - 10000 lb range and how it does towing? I know gas mileage may stink but I new that going into it. Starting to look at travel trailers. We are looking at trailers that are 25' to 28' in length. I really don't want to go over 10,000lbs but thought I'd ask.
We have a 36' tongue-to-bumper TT with a dry weight of just over 8000 and GVWR of 10,500. Tows very well and we have the same setup truck as you. I do use an Equalizer hitch, which I've enjoyed, also. We tow 8-10 times a year and normally on relatively flat areas. We've thought about going with a half ton truck next time with the max tow package, but that's a while out. You shouldn't have any issues towing the camper you described.
Thanks for the replies! This will be our first TT. We’re selling the Popup. Hoping to find something in the 25-26’ range. Found one that is close to 27 but is 32’ overall. My wife loves the floor plan but I’m a little leary of the length. We boondocked with our popup a lot and might be limited in some places with a bigger TT.
We tow a 35' total length TT at around 9000lb loaded with our 2011 F-250 CCSB and no problems at all.
I bumped up the suspension on the TT as it was light on springs and added an EZ Flex system to it.
Bumped the tires up to e rated and 100 mph speed rated tires as I-10 here runs 75 all day and 65 mph tires are a joke..
Go with the wife's choice of floor plan and you're golden. Don't sweat 2-4 feet..
Griz
Griz
My first trailer was a hi-lo with canvas sides and the bathroom was a shower curtain. I got kicked out of the trailer regular. There is no going back for me.
I do miss opening the sides up and getting a breeze....errr...not because she was in the bathroom....just cooler. I've run the a/c a lot more in the TT's.
my 2012 F 250 'xl' ,, 6.2L. with 3:73... 2 wheel drive with 159,000 miles..
I tow 1,800 miles each way... over 4 days.. and depart home below 30 degrees and 4 days later its over 95 degrees...
1,500 pounds in bed of truck... and trailer is 33 feet long... 9,000 plus pounds...
so a total rolling weight of 17,900 pounds from a Cat scale...
Towing a 34' 5er, scales at 12K loaded and wet. No problems at all. I'm not going to say it "pulls like it's not even back there", or some other inane statement. But, the truck is more than capable of handling the load. For towing, try using Manual Mode on the transmission. Best thing since sliced bread. And for mpg? Well, the faster you pull it, the more your mpg plummets. Big difference between pulling at 65 and pulling at 75. You're dragging a building sideways behind you in the wind. Worst mileage on record for me is 5 mpg. I was pulling on flat ground, into a 30 mph head wind. Just no way to win there. Normally on flat ground to rolling hills, we get between 8 and 9 mpg.
Enjoy your new camping lifestyle. We started off in tents on the ground, then a pop up, then a truck camper, then a TT, then a motorhome, now on our second 5th wheel.
I would say "floorplan" is everything, and get what you both like.
2012 F250 6.2L, 3.73 rear axle ratio towing 34'8" hitch to bumper TT weighing about 9.5K loaded with a Equal-Ii-zer hitch. Tow regularly through the mountain passes in WA, OR, ID, MT. As others have said, use the manual mode on the transmission and let it spin on the steep climbs. Transmission and engine temps are never a problem even on the hottest days. MPG: 8-9 depending on terrain and wind. Plenty of engine braking on the descents - occasionally touch the brakes but that's all.
Focus on the floorplan that you and your wife like best. Length is a consideration for some campsites but not really an issue for towing except longer turning radius. Sway isn't an issue with the Super Duty platform unless your WDH is setup wrong.
