1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2002 f250 replace the cig. lighter and power point with USB
Old 04-24-2018, 03:48 PM
CHESSIE JAKE's Avatar
CHESSIE JAKE
CHESSIE JAKE is offline
I know there are several threads about this already, but I'm looking for info. on a direct replacement usb port for both areas. I would prefer one that doesn't have a volt LED readout or a colored light. (I guess a white light would be ok) I don't want to modify the plastic dash if at all possible.
Old 04-24-2018, 04:11 PM
Brisco2's Avatar
Brisco2
Brisco2 is offline
Any reason you couldn't use one of these? I have them i all my trucks
Amazon Amazon
Old 04-25-2018, 01:35 AM
kgburns's Avatar
kgburns
kgburns is offline
Sumthing like this?
Amazon Amazon
I recently put one similar to this (I got one with a voltmeter display), same dimensions to replace the power point. It fit the hole perfectly, but I did have to change the terminal ends on the truck wiring.
Old 04-25-2018, 02:28 AM
10frank10's Avatar
10frank10
10frank10 is offline
glad to see you getting used to using the forum.
good luck with your build
irishammer
2004 - 2008 F150
02-22-2015 09:06 AM
megaede
Electrical Systems/Wiring
11-04-2010 09:09 PM
JohnG3
21
12-12-2008 09:00 PM
01F250marty
12-16-2007 02:48 PM
Quick Reply: 2002 f250 replace the cig. lighter and power point with USB
