Overdrive light
Overdrive light
I know this has been hashed to death but I recently bought a pristine 1996 F150 Eddie Bauer from orig owner. Garage kept since new. My OD light is blinking. Scan shows speed sensor bad or erratic. Sensor replaced but light still starts blinking above 45 mph. Scan again & get same code. Shifts perfectly, lockup is spot on. Speedo is all over the place. Could this be a wiring issue? Thanks for any help. These computer controlled vehicles are more trouble than my 46 2 dr Sedan Deluxe.
I will guess you have an 4R70W transmission.
So the PSOM output will cause the blinking but the shifting will be normal as the PCM will shift the transmission off the OSS and not the VSS.
The PCM may use the VSS if it is there but with it gone it will use the OSS.
But being speed related I would think your problem is more than likely in the rear end.
Yes and no.
The one in the diff is for rabs, speedometer, speed control and information to the PCM.
The OSS in the trans just sends information to the PCM.
I do not know the logic in the PCM for shifting with an 4R70W but I do know my 4R70W will shift OK with the speedometer (PSOM) removed from the truck. I do not know if it will shift with just the information from the VSS and nothing from the OSS. But it will shift with just with the OSS.
We do not get much information on this site from owners that have the 4R70W and have a speedometer problem.
It is hard to say if you have a bad PSOM or the rear end has a problem or bad wiring between the two.
So yes it could be a wiring problem.
The only way to know without replacing parts is to put a meter or scope on the VSS signal from the rear end.
Any help would be appreciated. Thanks Mark. Truck shifts as it should but after about 40mph the speedo goes nuts & od light comes on.
P0503 is vehicle speed sensor intermittent. That's the sensor on the rear differential. An intermittent code usually means there is a problem in the wiring to the sensor, not a problem with the sensor itself. You're going to need to electrically diagnose what's wrong in the harness.
Thanks...........I hate electrical issues. Rather build an engine, LOL
I got this thread mixed up with a different thread.
The Thread it was supposed to be posted in was this thread:
https://www.ford-trucks.com/forums/1...hifting-2.html
Sorry I do not know how I posted that in this thread.
Big Black Dually
45
03-03-2017 07:38 PM
bcaughhorn
11-13-2015 09:17 PM
Jayme Duty
01-30-2011 07:22 PM
