1952 F1 input shaft for 3spd manual transmission
I am looking to replace the input shaft for the 3spd manual transmission (column shift) for my 1952 Ford F1. While trying to replace the bearings and seals, I took the input shaft to a local shop to have the pressed-on bearing removed with a hydraulic press. The guy rushed a bit, and had the base blocks a little to close and it caught the small teeth and snapped a few off. To say the least, I was not thrilled, but now I am in need of a replacement input shaft. The one I need has 16 big teeth and 30 small teeth. Pictures attached. Any help/advice on where I could find one would be appreciated.
A break in the small teeth - painters tape holding missing piece.
About 3-4 teeth missing
Input shaft 1952 Ford F1 3spd manual
1952 F1 input shaft for 3 M/T
There are TWO different input shafts. 8M-7017 used with 3 M/T // 1C-7017-A used with 3 M/T & T-87 H/D 3 M/T
8M-7017 .. Input Shaft - 16 helical teeth; 30 clutch teeth; 8.25" long / Obsolete
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 9 = 800-476-9653.
1C-7017-A .. Input Shaft - 16 helical teeth; 30 clutch teeth; 8.27" long / Obsolete
NOS PARTS SOURCE has 1.
CARPENTER NOS OBSOLETE PARTS has 1.
MILLER OBSOLETE PARTS in Binghamton NY has 2 = 607-722-5371.
Highboy46
27
09-25-2019 07:14 PM
RoadTractor
09-11-2019 11:51 AM
df85732
04-12-2017 12:09 PM
