Relatively new 6.4 Starter failure, should I go with a 6.7 starter?
So just out of the blue, my newish 6.4 starter won't consistently engage the flexplate ring gear, it just spins. Luckily It starts on the second or third try. Anyone have feedback on the 6.7 starter. Also does anyone forgo installing the hidden bolt or is that a no-no. Cheers
I had my starter replaced around a year ago. It went out again around a month ago, so was towed to a repair shop. They replaced the starter with a rebuilt one. That one lasted around two weeks. They installed another rebuilt one. That one lasted less than a week. They then installed a new starter. I can tell the difference in engine spinning speed between the rebulit and the new starter. They said they will no longer install a rebuilt starter on a 6.0. They do quite a bit of work on 6.0 powerstroke engines. I also just spent the extra money for a new starter instead of a rebuilt for our motorhome's Cummins diesel.
Checkout LawDog starters. Everyone in the Facebook groups love them. I personally am running a used 6.4 starter. Once it dies, I will try out a LawDog. https://lawdogdiesel.com/products/si...torque-starter
Considering the range of total crap to Manufacturer rebuild being sold at RockAuto, it’s hard to say anything without knowing the brand.
My Ford dealer reman made it through about 60k without issue and still running, my used 6.4 OE Visteon from Diesel Redemption worked fine the short time it was in the truck.
I’m not sure how those Mahle purchasing the Letrika company, purchasing the Iskra company in Slovenia starters are. I’d probably ask Euroman about the rep in Europe. I’ve never heard of Iskra.
Even if the Autozone "Duralast" starter failed after 1 year every year.........., They would replace it every year until the truck went to the junk yard. (and then replace it on the "new " truck every thereafter!!)
