Question on Ford accessory stowaway rims ramps
I didn't get many responses back when I asked about these in January, but here's what was in that thread https://www.ford-trucks.com/forums/1...ing-ramps.html. By the way, I went ahead and ordered them on my truck, just don't have it quite yet. Maybe in a couple of weeks, as its getting the spray-in bedliner at GFX this week.
Had them
I had them in my 2015 F-150.
They are very sturdy, high quality, and come with a very robust cable lock system to keep them from becoming someone else's ramps. They mount to the bed walls with very sturdy mounts. If you wish to have a tonneau cover they do create clearance issues, depending on the cover.
if you need ramps, you will not regret ordering these.
what is the measurement from top of ramps to top of bed, I have backflip mx4 cover. Not sure they will fit by the way it looks. Thxs
I have some for sale here... came with truck, never used.
https://www.ford-trucks.com/forums/market/1535176
Not
Modifications to the brackets would take some doing, and you would need the ability to weld aluminum.
I am not sure how much you could lower them anyway, because there is not a lot of clearance above the wheel wells as I recall.
The ramps themselves are a problem when in the stowed position for any type of tonneau cover that extends below the bed rails.
Any tonneau system that sits entirely above the bed rails should not be a problem.
There is only an inch or so to the top of the bed rail. Below you might be able to drop them about 2 inches - if you could modify the brackets (or make your own). I have enough room to remove the ramps with my tool boxes on without trouble. I think the bed covers may be a problem if they have a center clamp - the end clamps both front and rear should not be an issue. You can see the tailgate anchor plate in the photo. No issues with that contacting bed covers.
