86 F150 300 Rebuild Project
Well guys, due to a slight water leak I have decided to do some work on the engine.
About 5 weeks ago I told myself I was going to replace the timing cover gasket and water pump.
About 3 weeks ago I did some looking online and decided I wanted to pull the engine and replace the oil pan gasket and rear main seal.
About 2 weeks ago I decided I wanted to pull the head and replace the valve springs and install a new cam
Last week I talked with my neighbor who is currently driving a racecar that has a heavily modified inline 6 engine in it.
Now I am pulling the engine completely rebuilding it. I have contacted a very reputable machine shop that will be doing the block work for me along with rebuilding the head.
As of now my basic plans are as follows:
1) Bore the engine over 20 or 30 thousands and install larger pistons and rings
2) Install a comp cam 252H or 260H
3) Install a dual plain Offy intake with a 600CFM 4 barrel
4) EFI Exhaust Manifolds (I purchased a set of OEM ones from EBAY that were off a 0 miles van.
5) Smooth out the intake and exhaust runners in the head prior to the rebuild. I have read about removing the "bump" inside, but I have not gotten mine pulled apart so I can confirm.
Whatever else you guys talk me into.
I have a deadline of 1 year to get this project completed.
All comments are welcome.
Thanks,
Cody
Thanks,
Cody
I just spent the past 4 and a half weeks repairing some old termite damage in the garage so now I can hopefully get something on the truck.
I hope to get the engine out this weekend. I have already removed the water pump, radiator, power steering pump alternator, and the bell housing bolts.
Hopefully I can just remove the motor mounts and the starter and pull the engine right out.
I have found some 7/16-14 UNC 3" long grade 5 bolts and about 3/16" worth of washers to mount the engine to the stand. This should give me around 13/16" or so thread engagement into the block.
Well, I had time this morning to get the head off and I found something I was hoping I would not.
It appears the cylinders are already bored over 40 over, and cylinder 1 has some nice score marks you can fill with your fingernail.
Its hard to tell from the photo below, but this is the cylinder that is scored.
I have a couple of questions.
1) Is there any issue having them bore the cylinders 60 assuming the score can not be cleaned up by honing?
2) Can the machine shop sleeve the first cylinder and bore it 40 over and just hone the other 5 assuming no other issues are found?
3) What would you do?
Thanks for your input.
Thanks,
Cody
Thanks,
Cody
Since it's already bored .04 over, and it's worn out again, I would start with a fresh block, since you're planning to add some performance goodies also. Any block pre-87 should work, and if you're lucky enough to find a 65-68 block, you can use 351W performance pistons with the earlier rods
I'm guessing you would not recommend going 60 over if the 40 will not clean up with a hone?
Thanks,
Cody
60 over can be a gamble, it likely won't go through the bore at that point, but it may get too close to the oil passages and water jacket and cause cooling issues. With a stock build, you could likely get away with it, but with a modded motor, it will be safer to get a JY block. Luckily, they're super common
Whoa! Gazing at your first picture....do mine eye deceive me or is that compression ring not seated in the piston? It looks like you could take it out with a scribe.....and the piston appears to be a good 0.025" away from the cylinder wall all the way around.
If it is, Holy Piston Slap, Batman!!!!
LOL, I believe you are seeing the reflection of the piston in the shiny surface of the cylinder wall giving the illusion of the huge gap. I actually had to go outside and check for myself.
Any thoughts on having all 6 cylinders over bored and install liners. I could then have all the pistons returned to the stock 4” diameter. Right now the machine shop I am talking to said it would be $300 to bore the cylinders, deck the block, clean the block, install freeze plugs, install cam bearings and magnaflux the block.
Anyone know the cost to sleeve a block?
Would this his not be stronger than stock?
