Oil pan threads stripped
Old 03-22-2018, 08:10 PM
cardsfanbj's Avatar
cardsfanbj
cardsfanbj is offline
I seem to have made a noob-ish mistake this last time around and I done messed up the threads on my oil pan. I got a new bolt from the local parts store and it seemed to have done the job for a week or two, but now I'm getting oil spots under my truck. I lifted it back up and sure enough there is oil dripping from the drain plug.
I'm assuming the drain plug is steel. I did test it and it was magnetic.
How hard is it to retap the hole? I don't have any experience doing it, and I'm wondering if I'm just better of going to a mechanic and have them do it.
Or how hard would it be to take out the drain pan? I'm finding replacement ones on eBay for under $100 and a gasket from Advance Auto goes for $28
2009 F-150 STX, 4.6L
Old 03-23-2018, 11:07 AM
WXboy's Avatar
WXboy
WXboy is offline
Rethreading the hole wouldn't be hard for a mechanic, but obviously you have to make certain to lube it up and catch all the metal shavings. You do not want metal shavings getting inside the oil pan.
Old 03-23-2018, 11:25 AM
jcnorton's Avatar
jcnorton
jcnorton is online now
cardsfanbj do you remember what the gasket on the repaire plug looked like? A budy had same issue, plug felt tight but seeped oil, the gasket looked like paper. He substituted a rubber gasket and has been fine ever since. Key is if yours is holding good in the threads, if so try a better gasket. make sure you get one that will hold up to petroleum products, one from a hardware may slowly dissolve and leak again. If this doesn't work then best bet for long term peace of mind is new pan. good luck
Old 03-23-2018, 12:34 PM
cardsfanbj's Avatar
cardsfanbj
So far, I've gotten quotes on it and the best I've seen is actually from the dealership for $400. Other repair shops quote $500-$575.
One place outright refused, telling me " We ain't gonna get involved in that. Just take it to Ford"
Most places are telling me they don't have any luck with Ford's oil pans and re-tapping them, they recommend just replacing them. The dealership said it depends on how bad the threads are,
Old 03-23-2018, 01:43 PM
Sportscape's Avatar
Sportscape
Sportscape is online now
Have you checked the drain plug gasket, crush washer? That's what is often a problem. A tap will not fix stripped threads, it may work if it's cross threaded. They make drain plugs for repairing worn thread , they are slightly oversized, some have a thread cutter on the tip. Your best bet might be to get a Fumoto valve if your threads are pretty good. If it will tighten up I think you could use a quality oil proof thread sealer , it will never need to be removed.
Old 03-24-2018, 10:50 AM
cardsfanbj's Avatar
cardsfanbj
Unfortunately, it's not the gasket that's the problem. It is the threads that it's not engaging with them tight enough.
Old 03-24-2018, 10:12 PM
meborder's Avatar
meborder
meborder is online now
Back when I was selling parts at advance, we carried a +1 size oil pan drain plug just for repairing slightly stripped pans like yours. They were a self tapping bolt just slighty oversized. Shouldn't be more than a couple bucks if they still carry them.
Old 03-25-2018, 11:30 AM
rbentnail's Avatar
rbentnail
rbentnail is offline
They still carry them, quick and easy fix.
mrad
07-04-2014 12:44 AM
yellow truck
07-22-2012 07:18 PM
randomhero1172
26
05-16-2008 07:49 PM
93F150/302
28
08-14-2007 12:07 AM
jvc100
11-05-2004 09:27 AM
Quick Reply: Oil pan threads stripped
