Bed / Cab Alignment
Bed / Cab Alignment
I noticed this the other day on my new F250 - the drivers side has a 1/2" to 3/4" offset b/w the cab and the bed but the drivers side is flush. It's not super noticeable unless you're looking for it specifically (I obviously never saw it when I bought the truck)
Wondering if this is an issue or they're all that way. Going to try to find some other Super Duty's in my daily travels and see how they're beds are aligned with the cab.
Yep, it's happened a few times here.
Loosen the bed or cab, your choice, and throw a cat at the side of the truck. Tighten up, good to go. Keep in mind, the bed is a hair narrower than the cab. I wonder if it was miss aligned at the factory, and the prep guys at the dealer only made it worse by realigning it perfectly, but flush on one side.
Ford always has the weirdest foibles.
Exactly the same thing here with my 2017 F250 CCSB. When I had Linex install the spray in bed liner we tried to move the bed over since all the mounting bolts were removed at that point. It wouldn't budge. They must move the cab I guess. Whenever something breaks I will have it re-positioned when I take it in to the dealer.
I've noticed this across all brands. I don't know why it's so hard for manufactures to line up beds and cabs? The Fords seem to be kicked off to one side.
On my GM trucks, the bottom of the bed tapers in towards the bottom. It looks strange, because the bed is flush with the cab up until about 12" from the bottom, where it starts to taper inwards. It doesn't line up with the cab corners at all.
