Adding front tow hooks to my 2018 F150
I'm looking for info to install the factory front tow hooks on my truck but noticed that mine has 2 front valance? It has the one valance with clips attached to the bumper where it has the area to cut out to install the tow hooks and the rubber covers, then below that it has another rubber valance attached with bolts to the higher one.
Has anyone done this modification and how did you cut out the cover area to make sure the rubber part fit correctly?
I'm not sure about the later models but I added chrome tow hooks to my 2010 F-150 2WD XLT. I replaced to front lower valance and installed tow hooks for an 4X4. I've seen some people just cut out the place in their original valance to accommodate the tow hooks.
I've got a brand new lower valance and chrome tow hooks I never got around to installing on my 2014 F-150 2WD Limited.
I considered doing cutting out just enough to fit the hooks through and at the same time it saves on the additional cost of the rubber boots cover things. If I don't like the way it looks I can always completely cut out the cover and install the rubber boots later. I don't like chrome if not I'd look into the part numbers and if they fit I would have bought those hooks from you. That's why I bought my truck all red and black, I've never liked chrome, don't know why.
I appreciate the offer. I have to go buy fuel (non-ethanol) for the lawn mowers in a couple of hours and there's a Ford dealership close by. I'm going to stop there and get under one of their trucks with tow hooks to compare what I have with theirs and see what I'll end up doing. Thanks !
I out of curiosity wanted to see how they attach. All I can say is its totally different than the way my hooks were attached on my 06 Ford. It looks like there is a different front cover used, since it looks like they molded in the openings for the hooks. Also the hooks are back covered a similar material as the full cover. I guess its for aerodynamics ? Here is some pics of the drivers side hook.
Thanks for the pictures. I went and got under a new truck like mine but 4x4 and even though it uses a different valance I got what I needed so I'm going to order the rubber hoods too in order to make it look like a factory installation. The only difference will be I'll be cutting my valance to exact minimums in order to not have those holes they leave on the sides of the boots when they install the hooks without changing the valance. I'll post pictures when I do it, should have everything here by next week.
Any luck?
Did you have any luck in doing this? Perhaps you can private message or post some pictures . I'm trying to do the same project, I have an 18 XLT
I received both hooks, hardware & rubber boots, but haven't had time to do it yet. Working on my taxes and that takes a while.
I had a chance to attempt this today. Easy job if you are steady with a dremel or sheetrock blade. I only had time to get one done as it's quite chilly here in Dallas. The most difficult/PITA part was getting to the two screws that hold the upper valiance in place. Thankfully, you can access them by popping off the square panel above it with a pry tool. They are 6/32 if my memory serves correct but don't hold me to it. You will need a socket extension. I am going to grab some sandpaper from Home Depot and charge up my dremel to complete the other side tomorrow.
https://photos.app.goo.gl/RsV5AVdLbNTvu4R52
https://photos.app.goo.gl/GD6fy0IW6TgElpuF2
https://photos.app.goo.gl/NcShtPNO8QwYKZ4E3
https://photos.app.goo.gl/jIv4XjLDNJJnPDx63
https://photos.app.goo.gl/nD2hvGBdpAScwGjj1
https://photos.app.goo.gl/CSmkyUNPZvtqkpRs2
Quick questions, why didn't you install the rubber boots to make it look they had been factory installed ( just $6 each side ) and why did you cut the top off of the valance if you weren't going to install the rubber boots and only needed a small opening for the hook to pass through?
I made a huge cutout for the tow hook because I am eventually going to install the factory boot. The boot needs to be tucked up into the chrome bumper but I don't have enough clearance to tuck it with the frame (the same bar the tow hook mounts to). I think the bumper may have to be loosened so I can snake in the rubber boot, then I'll tighten down the bumper again. I am searching the forums like crazy to see if the bumper can simply be "loosened" without a complete removal job.
Sounds like you have your summer booked. Here are some photos of the final product. I am probably going to see what the shops around her will charge to put in those panels. If I can find some fancy tape or weatherstripping to cover my dremel marks, I will be real happy with the final results.
Feel free to DM me for more info if need be.
https://photos.app.goo.gl/6TktVHD6ltMMdMmt2
https://photos.app.goo.gl/xnfqvTdIEnk2MWdE2
https://photos.app.goo.gl/GkfviuDwXp60RQQH2
