Cab still leaks after cowl cleanup
Cab leaked when I bought it.
1.Removed cowling, cleaned out both sides,
2.Sealed with seam sealer and spray flexseal and then buttoned it up with improved 87+ cowl.
3.Installed cowl weatherstripping
Water still drizzles into the cab via the metal plates covering the cowl vents every time it rains or when I aim the garden hose into the cowl.
What's causing this? I cleaned out from 3 places: down the top, through the cowl vent access, and even underneath through the duck bill.
I am not to familiar with those panels, but did they have a factory gasket?
Are you sure it's coming from the panel itself? My ranger has a leak in that area, but it leaks right at the corner between the vertical metal and the floor. I looked all over and there is no way I can get to that area on my ranger, so I just gobbed some roofing tar in the corner and it stopped. I am waiting for that to rear it's head again some day.
I also put the rubber plugs back in after cleaning.
The old bytel tape dries out and can cause a leak.
Now I don't know if they will use tape again or glue it like new cars are.
Dave - - - -
I was told you must use the butyl tape on these series of trucks, modern adhesive will not work in the long term. there are sheet metal seams in the channel, the butyl tape is thick and "conforms."
The modern "goo" method is too thin will not hold and is actually un-safe.
A couple of years ago after I painted my truck, I called all the commercial glass companies around here and they would not do the job, But found a local, smaller guy that was familiar, with these trucks, I mentioned adhesive, and if he could have choked me over the phone, he would have.
He also mentioned the trim actually puts constant "tension" on the glass too.....
Before he installed the butyl tape, he had a powerful cleaner, solvent and cleaned the windshield channel down to original paint, removed everything, we found some cracks and re-seam-sealed them, ...Say it aloud to your self, SEAM SEALER, not silicone!!!!!!!!
Silicon rusts sheet metal!
Silicone repels new paint!
Silicone will resist the new butyl tape!
Throw away all silicone in your garage, (unless you rebuild engines, trannys and diffs)!
No silicone on sheet metal.
Get the hint?
Also look very closely at the top corners where the trim has the 90 degree bends, ANY micro cracks from there and along the 3-seam rain gutter above your door is your leak. And YES, the duck bill plugs must be re-installed...
TEST: if you find a crack in the rain gutter, what are you going to use to seal it up?
Get the hint?
