4x4 clunk
4x4 clunk
I was backing up a trailer yesterday, and put the truck in 4x4 low. After the shift message went away I gave it some light throttle then heard a load clunk sound. The steering was turned pretty far to the right before I put it 4x4 L, and when I started to backup. Didn't like what I heard, looked under the fenders for anything wrong, put it back in 2wd, and pulled around the block to get a better angle backing up. Put it in 4x4 auto, and backed the trailer into my driveway. I felt some odd thumps when the wheel was turned close to full travel. Finished playing musical chairs with the trailers in the yard without further incidents.
Truck is a 2016 F150 4x4 SuperCrew 3.5L eco 6 speed auto w/tow mod 3.55 elect lock RR axle lifted on 325/60R20 tires. Truck was lifted by the selling dealer, and has been back to the local dealer for 4x4 problems before. Odd thumps and noises have been felt and heard before while turning sharply in both 2wd and 4x4. Truck is my mother's. I'm not familiar with 4wd trucks, or newer ones; I've only owned 2wd old trucks.
You should be good on the surfaces described. Occasional binding happens and won’t hurt if you correct it right away by straightening the wheels or shifting back to 4x2. When there’s binding you can usually feel it in the steering wheel.
if there is a clunk, and you don’t feel it in the steering wheel, you may need to lube the splines on the front driveshaft.
I’ve also found that the shift to 4x4 isn’t immediate, going in or out. When I shift out of 4x4, I do it before I park so there is time for it to fully disengage.
Clunks and lurches going in and out of 4WD are almost normal for these kind of systems. Because they're not fully engaged all the time like an AWD system, gears have to mesh and parts have to come up to speed if the truck were moving.
Shifting to 4-low from a dead stop makes for a tough shift in the transfer case because the gears may not be lined up to mesh when you turn the switch. When you apply power, the gears probably meshed suddenly and engaged hard. Hard turns are harder on the system, as is engaging the system from a dead stop. Next time try shifting to 4-low with the wheels straight before the traction is needed, and do so with the truck slowly rolling from 1-3 MPH. The owner's guide should say this as well.
