End stand requirements
03-17-2018, 01:49 AM
on
How big of a cam can I run before I need rocker rail end stands?
03-17-2018, 01:51 AM
on
End stands
How big of a cam can I run before I need rail rocker end stand supports?
03-17-2018, 07:44 AM
WELCOME to FTE!
The spring pressure is a better indicator of how much you need end-stand supports. I wouldn't know, I ran .554/.554" lift with the stock rocker shaft setup.
Someone will be along to offer an opinion soon
03-17-2018, 06:58 PM
Spring pressure, valve lift and rpm all play a role.
Our valve lift is .736
RPM 7000
If I were you, I would use end stands on anything above 6500 rpm and .600 lift with dual springs. It's good insurance.
We have one piece solid billet aluminum stands, from a company that is no longer in business. To bad, because there is virtually no deflection.
03-18-2018, 04:56 PM
Nice looking rocker setup. Who made it?
I've got a Erson setup with two piece stands.
03-18-2018, 09:06 PM
Quote:
Originally Posted by
Destroked 450
Rocker Arm Specialties out of Redding California. Unfortunately they are out of business.
bear_
12-23-2015 01:37 PM
77f100guy
07-19-2010 08:37 PM
jerg_064
08-07-2008 03:28 PM
water 5
09-05-2006 08:58 PM
tastyklair
13
10-20-2004 04:10 PM
