6.2 Muffler Delete Opinions
I have searched through all the threads I could find regarding a 6.2L muffler delete. For those of you that have done the delete, are you still happy? How is the drone at highway speeds?
I have only been able to find 2 videos on YouTube from an FTE member, and from what I can tell it sounds pretty good.
I love the delete on my 6.2. Sounds just like stock but with maybe 15% more sound. Just a little bit more drone but I think it's the perfect amount. Doesn't bother me when towing at higher rpm for several hours either. Even after a year with the muffler delete I still remote start the truck nearly every time I walk up to it just so I could hear the bark of the exhaust when she fires up
This was one factor to convince me to trade it for a 6.7 PSD!
Did you have a muffler shop scab in a straight pipe? The shop I called said it would be cheapest if I provided a section of 3.5in stainless that they would use in place of the muffler.
Thank you for the feedback. Is your delete muffler only, or one of the resonators as well?
A straight pipe was put in its place. Is memory serves the inlet and exit to the muffler are slightly different diameter, can't remember what the shop did to accommodate for that but it was easy.
“A straight pipe was put in its place. Is memory serves the inlet and exit to the muffler are slightly different diameter, can't remember what the shop did to accommodate for that but it was easy.”
The pipe inlet on the muffler is 3" and 3.5" outlet. They flanged the pipe on each end and welded it in place on mine.
