rear gear ?
Old 02-25-2018, 05:30 PM
ru67's Avatar
ru67
ru67 is offline
rear gear ?
My 67 truck came originally with the 352 engine and (code C) 3-speed transmission, and rear axle (code 17) 325 gear. The guy i bought the truck from removed the 3 speed trans and installed a C6 automatic, and i now have installed 18 inch rear wheels and tires on it. Now at 65 mph its turning more RPMs than i like on the interstate. I thought some of you might be running this same ( C6 trans,18"wheel) setup and could tell me what rear gear you might be running to get decent rpms at 65-75 mph on the interstates ? Also on these 325 gear, what spline axles were used ? Thanks for any information you might provide.
Old 02-25-2018, 05:39 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by ru67
My 1967 F100 came originally with the 352 engine and (code C) 3-speed transmission, and 9" rear axle (code 17) 3.25 gear. The guy i bought the truck from removed the 3 speed trans and installed a C6 automatic, and i now have installed 18 inch rear wheels and tires on it. Now at 65 mph its turning more RPMs than i like on the interstate. I thought some of you might be running this same ( C6 trans,18"wheel) setup and could tell me what rear gear you might be running to get decent rpms at 65-75 mph on the interstates ?
Also on these 9's what spline axles were used?
B7TZ-4234-A (replaced B7C-4234-A) .. 9" Rear Axle Shaft with 28 splines / Obsolete
Applications: 1957/67 F100.
Old 02-25-2018, 06:25 PM
ru67's Avatar
ru67
ru67 is offline
not sure I'm understanding what you are saying in your reply ?
Old 02-25-2018, 06:39 PM
NumberDummy
not sure I'm understanding what you are saying in your reply?
1957/67 F100's w/a 9" rear axle have 28 spline axle shafts.
The axle shafts are the same right & left for these years, why I listed the part number.
Old 02-25-2018, 06:42 PM
ru67's Avatar
ru67
ru67 is offline
got you ! Thanks
Old 02-25-2018, 08:51 PM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
Google a speed calculator, there are hundreds of them. Plug in the info and you can see what the rps are. 18 inch wheels don'r mean much, you need tire diameter and if you have some low-pro car tires on it or have some Pickup 35s is going to make a world of difference.
Old 02-26-2018, 09:41 PM
351Cleveland C4's Avatar
351Cleveland C4
351Cleveland C4 is offline
Yeah, wheel diameter doesn't mean jack....
3.25 gears are pretty good. Get taller tires or swap for some 2.75 gears.
Old 02-27-2018, 02:10 PM
hivoltj's Avatar
hivoltj
hivoltj is online now
What size tires are you running? My dent is lowered 5.5" in the back and I can still run 29" tall tires
Old 02-27-2018, 08:55 PM
ru67's Avatar
ru67
ru67 is offline
my back tires are 29" tall .
Old 02-27-2018, 09:10 PM
351Cleveland C4
Get taller tires, swap to 2.75 gears, or put a gear-vendors overdrive on the back of the C6.
Old 02-27-2018, 09:56 PM
willowbilly3
So you are cruising 70 about 2600 rpms. The 2.75s would put that about 2200. But you can add a couple hundred rpms with the C6. IMO, that transmission only belongs behind a big block because it robs so much power. The best answer is to instll some sort of overdrive.
Old 02-28-2018, 06:00 PM
ultraranger's Avatar
ultraranger
ultraranger is offline
Ding ding. Nothing is going to make as great of a change (improvement) than having an overdrive. Going with high gears (lower numerically) will give you less engine RPMs and gas consumption at highway speeds but, the trade off is the truck will be less responsive to acceleration and there will be more difficulty pulling a trailer/hauling a heavy load.
Having lower gears (higher numerically) gives better acceleration response and greater ability with ease to pull/haul a heavy load. The downside is higher engine RPMs at highway speed and greater gas consumption.
With an overdrive, you can keep your rear end gear ratio and accomplish both scenarios.
Old 03-06-2018, 09:19 PM
ru67's Avatar
ru67
ru67 is offline
I want be pulling anything or even hauling anything.Was just looking to lower the RPMs for hwy cruising. This is kinda a cheap fix desent looking (shop truck sorta) and I really didn't want to change the transmission.Thanks
Old 03-07-2018, 09:19 AM
MIKES 68 F100's Avatar
MIKES 68 F100
MIKES 68 F100 is offline
BIGGER DIAMETER TIRES IS THE CHEAPEST FIX
Old 03-07-2018, 11:11 AM
351Cleveland C4
Agreed.
Depending on what you want/ like/ can live with, I've seen 35x10.50 tires for 17" wheels. Those would do the job haha
But more realistically speaking, 31s, 32s or 33s would probably be a better fit.
Quick Reply: rear gear ?
