86 f150 302 efi heads
Look at the lower front corner of the passenger head next to the valve cover. There should be a letter cast there. E6's have an "S" here. E7TE's have a "T" in this location. If there's no letter then they're earlier heads. GT40's have "GT" here or GTP on the P heads. Same thing on the lower rear on the driver's side head.
Most likely the E5 heads. But could be E6. You can mill those GT40 heads .040 and pick up a half point in the ratio. Best head gaskets to use are the stock expanded graphite gaskets, Felpro 9333. I use these with my Canfield aluminum heads, liberally coated with Kopper Kote spray.
on
That is because these trucks were dumping grounds for all kinds of parts that Ford was trying to use up including engines and engine components. Technically the E6SE car head should never be found in a truck but for whatever reason the low-po 5.0 Crown Vic motors found their way into trucks anyway.
fordfan66
12-06-2010 09:41 AM
Tsaven Nava
01-10-2006 08:34 AM
123michigan
07-20-2005 05:10 PM
ramdodger
02-17-2004 04:22 AM
