Head rebuild kit
I understand what you're saying though, which is why I do literally everything in my ability myself. My expectation of them is moot in that case.
Thanks guys for all the replies, will check on the parts prices at the machine shop. Would be easier than tracking them down online anyways.
QUOTE='89F2urd;17820362]That's probably the best deal honestly, unless you wanted to port your head while it's disassembled.[/QUOTE]
Yeah I'm looking to get more flow in the top end it seems a little restricted... I feel like the truck should be able to go a little faster than 65 uphill. I know the 300 is all low end but 65 uphill in 4th gear... Somethings wrong. Ill have them clean the intake out as well and probably the block since I'm pulling the motor anyways.
Well, 65 uphill is relative. There are a couple hills aroumd here that I can't do 50 up unless I drop from 5th to 3rd and that's if I'm already doing 50.
It all depends on the grade of the hill.
And then, you get into gearing. If your truck has a 2.73 or 3.08 gear rebuilding the head probably won't help much. You should do a cylinder leakdown and compression test. If those come back okay, then the engine is most likely not the issue.
Yeah that's what it's looking like, save time and headaches. I really wanna get this thing going. Starting a new job 6 hour drive every 2 weeks and I dont wanna take any chances.
Ahhhh ok well a know bad head gasket is a good reason for a top end job.... If you are just doing head work make sure you get the right head gasket. Do Not go thicker than factory, this will throw the quench distance off and can cause detonation.
