2006 Grill Guard Fit?
Old 02-18-2018, 10:48 PM
Colorado350's Avatar
Colorado350
Colorado350 is offline
Question 2006 Grill Guard Fit?
As the title says, I found a grill guard off a 06 F250, will it fit our trucks? (E99) Thanks.
Old 02-19-2018, 06:12 AM
DieselDenny's Avatar
DieselDenny
DieselDenny is offline
I'm pretty sure there wasn't a frame horn change. Should fit.
Denny
Old 02-19-2018, 07:25 AM
Sous's Avatar
Sous
Sous is online now
Received 4,460 Likes on 2,850 Posts
If you know the model of the grille guard, you could look up the instructions online and see if they match or are feasible for your application.
Old 02-19-2018, 07:56 AM
Dan V's Avatar
Dan V
Dan V is offline
The bumper and valance changed in 2005. Look and the various front end swap thread that detail installing a 05-07 bumper/headlight, grill in the 99-04 years,
Old 02-19-2018, 03:50 PM
Colorado350
Good ideas guys, I see if he has a model number. s
Old 02-19-2018, 08:34 PM
Jaime74656's Avatar
Jaime74656
Jaime74656 is offline
Depending on what year (assuming 2006) your header panel, grill and bumper will be different then e99
Old 02-20-2018, 09:01 AM
mcnance865's Avatar
mcnance865
mcnance865 is offline
It should fit as far as attaching to the frame, however the "cross bars" in front of the lights may not match up depending on brand (thinking ranch hand) and the corner bumper guards (if it has them) may not line up very well. Could you attach a picture so we can see what style grille guard you are referring to?
Old 02-20-2018, 09:18 AM
Colorado350
Here is a picture of the grill guard. I can weld and do some fabrication but I don't want to have re-engineer the damn thing to get it to fit properly.
Old 02-20-2018, 09:59 AM
mcnance865's Avatar
mcnance865
Most likely that will be fine since it does not have cross bars over the headlights and does not really have corner guards. It may take some adjusting/adding brackets at the frame but I'm not sure.
Old 02-20-2018, 10:02 AM
mcnance865's Avatar
mcnance865
However, do NOT take my word for it; you should measure and/or test fit before you buy. I do not recognize that grille guard, so I have no idea what brand it might be. I am just going by the design of the bars in front of the grille, never seen that before.
kingeightclub
1999 to 2016 Super Duty
01-13-2012 01:44 PM
SPELLY F150
02-29-2008 12:40 PM
Livewire68
12-24-2007 12:15 AM
cbsaf
2004 - 2008 F150
12-18-2006 05:40 PM
6.0 powerstroker
11-03-2004 01:39 PM
Quick Reply: 2006 Grill Guard Fit?
