hi members is there a thread on getting turn signals to work mine are all wired in but not blinking and when a test light is used the test light is dim and not blinking either from under the dash at the wiring connecter im using a gm column any suggestions ?
Sounds like a bad ground. You can never have enough of good grounds and make sure that the grounds are to bare metal and no paint between the connections.
What year/model of truck? ET is right about the electronic flasher IF you are using LEDs. Otherwise I agree about checking your light grounds. Don't forget the flasher ground which may be the metal can bracket on some non-electronic flashers.
well while testing things i was checking power at the steering wheel connections and unless i have the test light on the right side connector it wont flash at all the left side wont no matter what i do ????
If you are using the older style flasher they require a certain amount of current flow to heat up the by-metal spring to make it flash. Your test light does not draw enough current to make it work. regards Bruce
