2003 F350 Door Ajar Light
door ajar problem
I sprayed mine down with WD40 and pull the switch out and cleaned it, but still door ajar light on and chime dinging. Radio also stays on for 10 minutes before shutting off. Cab lights don't light up until after running pickup and shutting key of then open door and they come on. Could this all be because of the door ajar sensor switch on driver door? My truck is a f350 super duty.
Last edited by 02f350blanchard; 03-13-2018 at 02:11 PM. Reason: forgot type of pickup
02f350blanchard,
The radio staying on for 10 minutes sounds normal to me, but the door ajar light, chime and cab light operation all sound like what I had when my door ajar switch needed replacement. The cab light times out after about 30 seconds because the vehicle thinks the door is still open, even though you physically closed it. I replaced the switch on the driver side door and all was good; did not worry about the passenger side since the driver side door usually gets 10 times more use.
Ron
Ron
Door ajar problem
I've tried all the fixes suggested and still no change. That's including spending $47 on a brand new door ajar switch/sensor. Nothing I do works. I cannot lock or unlock with my remote keyless entry. So I use the driver side door lock button and all four doors lock, but then the driver door unlocks. I have to manually push it down to get it to stay locked. By deduction, it seems as if it's a security system problem, but I don't know where to look for the solution.
