3.5" procomp nitro w/ 37s?
A 7" lifted 17 is huge compared to a 7" lifted 6.4. The 35s will look a bit small; not overly small, but you will definitely notice it.
But can I fit 37s with aftermarket wheel and maybe a little offset? Don't really want them tucked like stock but don't want them sticking out 4"
Check out customwheeloffset.com. You can search 17 superduties and various tire sizes in gallery. I am running 35s x 13.5s on 20x10” rims with -24 offset with a 2.5” Carli leveling kit and have zero running. I ran them stock with significant rubbing and needed to do some plastic trimming and bend back a 1/4” metal tab in the wheel well. I see guys running 37s with leveling kits all over and as mentioned above with stock height as well. The stock height 37 guys are running them with stock rims mostly though. Offset definitely makes a big different with rubbing.
All depends on the look you want. Check out the site noted above, there's TONS of examples of 17-18 Super Duties on there with various lifts, level kits and wheel combinations. I'm running 20x10 wheels with a -19 offset, wrapped in 37x13.5x20 Toyo RT's, and 1.8" flares. Tread blocks are covered, only a slight sidewall poke. I have slight rub on the bottom/rear of the flares, I've trimmed as much as I could to make it clear. A 6" lift vs. my 4" would do the trick. Next time I guess. Good luck with your search.
I guess on look I would like them to stick out some but I don't want to have rubbing issues
JBradley500
07-05-2006 12:06 PM
mtgrzlyman
07-19-2005 02:13 PM
