2011 DUally 6.7, H&S tuner S&B intake EGR delete DPF delete install, now proble......
Been a member for a while, mostly just a reader
Not sure if this is the correct place to ask for help but here goes
Waited till warranty was up at 100k miles. Took my truck to a local recommended shop (I'm kinda out in the boonies, so I do t have much selection, but this shop came recommended by a fair number) and spoke with them about doing the following. I wanted to get rid of the DEF requirement (I've had 4 tank/heater unites replaced under warrenty) also wanted to better my mileage, 13 mpg stinks. As well wanted to do anything I could to help the longevity and health.
The shop recommended
H&S Tuner Install
S&B intake install
DPF delete
EGR delete
Shop seemed very competent and knew what they were talking about, so i pulled the trigger.
Allow me to preface this with this statement. Prior to doing this I had no pre existing issues.
Well all the work is done but now I have this xhaust thumping sound at idle, and only at idle, coming from the tail pipe. Almost kinda like what an old school glass pack sound like at idle. Now the mech isolated it to certain cylinder by shutting off the injector via scan tool, noise goes away, but an obvious mis. Turn it back on miss goes away but the thumping sound comes back, but it's only at idle.Rev the engine it goes away, take the truck for a drive, it goes away, come to a stop and it slowly comes back. Every now and then at idle the sound goes away but it correlates with what I was told was the turbo variable stators adjusting.
Did a compression check and it's good at 360.
Now I'm being told by the same shop I now need a valve job done on the cylinder, that the sound "could" be a result of exhaust valve putting and not seating well (but yet the compression check comes back good) well we all know what that means.
I had the shop finish up the work that was done and I would get back with them and took my truck home. Now it runs great and I can tell a noticeable difference in performance, and again, no exhaust thumping noise, only at idle.
Any thoughts on this guy's?
ALSO what would be a fair price on all the work I had done ?
H&S Tuner Install
S&B intake install
DPF delete
EGR delete
Thank you in advance
H&S Tuner Install
S&B intake install
DPF delete
EGR delete
H&S Tuner Install
S&B intake install
DPF delete
EGR delete
I would suggest that this 'problem' has been there for quite some time you just haven't been able to detect it with the DPF in the way of the exhaust.
Personally I would be tempted to leave it until it really causes trouble. You may drive it the way it is for a long time without issue. Perhaps a couple tanks with injector cleaner would be a good idea.
If you have any friends that have the same set up on their truck, have a listen to their exhaust for comparison.
Some people pay extra for that sound
have you run different levels on with the H&S? I presume it came with a few. perhaps a quick video at idle as well?
As for cost, I spent approximately 1200 for the hardware and tuner to do mine. Didn't do an intake though. Took me 5ish hours to remove exhaust, install block offs and set it up.
ok heres an update
to answer a few questions, it has had an injector replaced(#8) a few yrs ago, but not the subject cylinder (7) pulled a code of the computer of P0281 which comes back as cylinder 7 contribution balance fault and this confirms when we turned off #7 and the thumping went away.
So we replaced the injector....................did not fix Grrrrrr!!!
like I said its only at idle, and around 1000rpm the thumping goes away. As well when at a stop light, the engine idles a bit different like its adjusting something and the thumping goes away for about 30 sec, but after the engine is done adjusting, it comes back. There is no engine sound, thumping, knocking or anything coming from the engine, and as stated earlier, before doing all this work, there was no thumping.
Here is a video.
Here is a video.
If it were me I would remove the tuner (return to stock tuning) and see if it runs right. I haven't heard of it happening before but it might be that your H&S tuner has a bug in it that is messing up the no7 injector pulse.
If it runs right then you could try reloading and going with a different tune (power level) or else you could have the tuner re-flashed or repaired somehow.
Even if you load the stock tuning keeping it deleted, I think it will start just show reduced power screen immediately, that’d be quick check.
Quick compare, this is mine deleted no muffler(s)
https://youtu.be/GRDvcrmHo0A
I can hear a different thump in yours as you have described
I'm leaning more and more like it was there priviously, just couldn't hear it like what a few have mentioned.
Well I'm getting a quote on a rebuilt head...
Eeesh.
Figures, I just paid it off.
Thanks all.
Wonder if I should have both done? Or just do one and if the thumping comes back from the other side have it done.
If my memory serves me correctly it's usually the drivers side head that had the issues... possibly because Ford had the brainwave to send fuel for regen only through that side on exhaust stroke.
