Smoke, then clears up
Hi all, problem started Saturday morning.
I warm my truck up for 2-3 minutes, drive about 4 blocks (no issues) and I see white/grey smoke coming out of tailpipe-always starts smoking in same location. EOT and ECT are 125-135, I can drive it for another block and it clears up, only smokes at idle and light throttle. Once it clears up (quickly) will not do it for the rest of the day driving around.
My mechanic seems to think it could be a turbo gasket......any other idears?
Did the bullet proof include a new EGR cooler?
Losing any coolant?
You can pull the downpipe loose to see if it's getting oily, which might point to a turbo shaft seal leaking.
If there is no hint of coolant smell at the tailpipe that might narrow it down more.
Blue smoke=fuel
White smoke=coolant(unless it's really cold, then it's normal......not going to affect you where you are)
Grey smoke=oil
Badgerproofed, it was badgerproofed.
I went through the same characteristics. There was a small contribution of smoke due a lazy EGR valve if you still use the EGR as working, but the real culprit was an injector that developed stiction. AR9100 helped somewhat, but it required checking the injectors with IDS uncompensated to find the injector, replace it and solve the problem.
Yes, updated EGR cooler with bulletproof. Ill check the downpipe, I did notice more than normal oil around boot closest to turbo.
No coolant smell and smoke is grayish, definitely on the lighter side of blue/black.
I think my tuner deletes EGR? I run rev X for stiction, but will have my mechanic check like you have said.
Thanks guys, just trying to get some idears before taking to mechanic on Thursday
shivaskeeper
01-25-2021 12:33 AM
chesterstroker
6.4L Power Stroke Diesel
01-11-2014 08:33 PM
