Headlight bulb upgrade
I have a 96 F250 and am in need of a new headlight. it is a 65/55 bulb system. I see brighter bulbs available so am wondering if a electrical issue would be created by installing the 80/100w bulbs. Would I need to do some electrical plug upgrades??? would the brighter bulbs work just fine in my system without making additional changes?
Years ago I ran 80/100's on my Toyota 4X4 with no issues. However, our trucks run the power for the headlights through the headlight switch. The OBS headlight switch is known for melting down or sometimes even starting fires when it malfunctions. Therefore I would recommend installing a headlight harness before upgrading to a higher wattage bulb. The harness uses a relay to trigger the lights so they draw directly from the battery or other power source without going directly through the headlight switch. There are lots of threads on here about making or buying one and installing it. It's on my to do list for my 92.
Some people have posted that installing the harness has improved their lights so much they didn't need to upgrade.
The first and best upgrade is head light relays.
The best bulbs I have used are Phillips Extreme Vision and GE Nighthawk.
Over wattage bulbs are generally a bad idea. They operate too hot and can melt assemblies and connectors etc. Not to mention the fact that it is illegal.
Also stay away from any bulbs that have any sort of coating on them. This includes the popular Silverstar which is garbage.
New CAPA-certified replacement headlights from any of our vendors and a headlight relay harness would go further than wasting time trying to restore the existing twenty-two year old headlights. I just did this with my truck and the difference is staggering. My headlight harness kit is on order along with some Vosla +100 bulbs.
A note about bulbs; Do not waste your time with any coated bulb. Coatings only diminish the light output. Get a bulb that has a clear capsule for maximum output.
Also, from doing some reading and research, Sylvania bulbs seem to be pretty low on the pecking order. They also seem to be the prevalent brand in most auto parts stores in my area. Philips or Vosla bulbs will most likely have to be ordered from any number of online sources.
Last edited by raystankewitz; 01-21-2018 at 07:28 PM. Reason: make info a bit clearer
If you don't like OEMs I don't know. I put new lenses on my factory housings IN THE TRUCK. No adjustment, no disassembly of anything. It took a little fit up trimming on new lenses and a fat bead of clear silicone two years ago. Maybe get a rollbar in your bed and put stadium lights on it like Walker Texas Ranger.
on
I don't have a clue about the quality of that harness. I do find it to be a very low price similar to the LMC one. I know you cannot buy all the best components for that price. BUT....I'm not familiar with it so it may be a loss leader. Take a look at CE Auto Relay Kits and see if you can figure out the difference. You want top of the line relays (Hella, Flosser etc.) and top of the line connectors. Perhaps there are some folks on here who can chip in on the big cost difference.
The harness basically supplies full battery voltage to your headlights. For example, I had just a touch over 10 volts at the bulbs, backprobed at the socket without a harness. Mind you, Battery voltage on my truck is about 14.3 running. I was giving up almost four volts and as far as lumen output, that's giving up a bunch of lighting. The OEM wiring to your headlight switch has some 18ga wiring in it, insufficient for full output. A harness fixes that inequity. It also saves your headlight switch from burning up on you, taking the headlight switch plug with it.
on
For example, I had just a touch over 10 volts at the bulbs, back probed at the socket without a harness. Mind you, Battery voltage on my truck is about 14.3 running. I was giving up almost four volts and as far as lumen output, that's giving up a bunch of lighting.
________________________
Daniel Stern Chart Listed Here
"Headlamp bulb light output is severely compromised with decreased voltage. The drop in light output is not linear, it is exponential to the power 3.4. For example, let's consider a bulb with a rated output of 1000 lumens at 12.8 Volts and look what happens when it is operated at different voltages":
10.5V : 510 lumens
11.0V : 597 lumens
11.5V : 695 lumens
12.0V : 803 lumens
12.5V : 923 lumens
12.8V : 1000 lumens ←Rated output voltage
13.0V : 1054 lumens
13.5V : 1198 lumens
14.0V : 1356 lumens ←Rated life voltage
14.5V : 1528 lumens
____________________________________
Wow. according to Daniel Stern's Chart you were running on about 33 percent of your potential lumen output.
10.5V : 510 lumens
11.0V : 597 lumens
11.5V : 695 lumens
12.0V : 803 lumens
12.5V : 923 lumens
13.0V : 1054 lumens
13.5V : 1198 lumens
14.5V : 1528 lumens
10.5V : 510 lumens
11.0V : 597 lumens
11.5V : 695 lumens
12.0V : 803 lumens
12.5V : 923 lumens
13.0V : 1054 lumens
13.5V : 1198 lumens
14.5V : 1528 lumens
WA_PSD
33
02-12-2012 12:22 AM
