5.8 / 351w hesitation at highway speeds
I have a 1995 f350 crew cab 2wd with the 351w. It idles fine and will drive for 30 or 45 minutes, but then chokes and will not go over 50 mph. I have replaced the fuel pump, filter, distributor (the whole thing), ICM, coil, plugs and wires, throttle position sensor, and fuel pressure regulator. I'm at a loss here. Fuel pressure was fine at 40 to 42 but now I can't even get a reading. I tried a different gauge and still can't get a reading, but it's running fine so I have to assume it has pressure. If I press the valve, it shoots up at least a foot. Any help or ideas is greatly appreciated. Oh, we put a new catalytic converter on it as well. Do I need to reset the computer after the cat install??
McBusiness11
17
02-05-2018 05:30 PM
Tater7633
16
05-08-2015 10:06 AM
Michael Unger
27
12-12-2008 09:02 PM
