Wiper arm tension. How much is enough?
After two sets, my wipers just smear the water, one set bounced, and are noisy as can be. When we got snow, THEY DIDN'T EVEN TOUCH THE WATER! Just swept over it all like nothing.
How can I tell if I need new arms or just got two different brand sets of bad blades? Glass is as clean as I could get it with alcohol and windex. Not greasy smear though.
What blades are you running? I'll use blades from the parts store when I have to, but really prefer OEM. And since OEMs last longer than the parts-store blades, they really are not that much more expensive.
And I get much better wiping after I clean the blades with alcohol when I do the windows.
The last time I bought at the parts store, I got Trico. They streaked a bit, and lasted about 6 months. By then, I had stopped by a stealership and picked up the right ones for the vehicle. The Icons are rated better, but the price was higher too.
OP - how much are you spending on the wiper blades? I've found around 20 each buys good ones.
Do you have stock length wiper blades?
I bought longer wiper blades and had the same thing. The spring in the arm is worn out and doesn't put enough pressure down. It needs new arms. Haven't done it yet but I know it's possible to run longer blades, I had it on a previous truck and it worked fine.
I had issues with weird spots on the windshield that the wipers wouldn't touch. seemed like the arms weren't putting enough force behind the blades to get the rubber blade to hit every where on the glass. Tried a few different blades with same results.
Ultimately just bent the steel wiper arm towards the glass to get get more tension in the spring in the arm. It' fairly thin, you can do it by hand. That worked. I think the spring just lost tension over the years. Might want to try that.
The bend it method worked, But both the michellen and bosch pull water back on the down pass and still noisy as hell. Getting an OEM set in the morning. But, bending the arms did help dramatically. Just need to get by for now. If it lasts a year like this, great.
Jeez, It seems with these trucks only OEM stuff works like it should. None of the aftermarket really does ironically.
