adding power brakes to bullnose
is adding power brakes easy as hooking up brake booster or is there more to it all my lines brake pads/shoes rotors/drums master cylinder need some attention old girl has been neglected by the previous owner i thought why i am working on it all might as well try to go power ???
1981 f100 4.9l 300-6 rwd srod
I did this on my 81 f100, the only hard part is that you need a power brake pedal. The pin for the rod sits lower (I think) than the manual pedal. The pedal is pretty easy to swap, there is a couple spring clips and the rod slides out. If you have access to used parts (wrecking yard) for the pedal it’s a worthwhile swap.
The same valve (EOTZ-2B257-A) was used 1980/83 F100/150 & Bronco & F250's under 8,500 lbs. GVWR
Because of swapping brakes on other makes I knew to swap pedals and sure enough the power & non-power are different on our trucks.
I swapped the whole assy. as both trucks were sticks only difference was power/non-power brakes.
I don't remember what one is power or not.
I cant remember on the lines as I could have used the power lines from master to the valve on the frame. If the fittings are the same you may just need to bend them a little to reach the master that is out farther from the fire wall.
I have not driven the truck yet but don't see I would have any issues.
Dave ----
With that said I guess I took the power master lines to use on my truck.
I would say get everything from the junk yard: pedals, booster, bracket(s), rods, master & lines.
Then what you may want to do is get a rebuilt booster & master, sometimes sold as a complete unit, and use the JY parts as cores.
Dave ----
brendo613
05-19-2018 04:11 PM
mikedanger
13
02-28-2011 11:45 PM
THEGAME304
12-18-2005 11:52 PM
f100beatertruck
05-25-2003 11:09 PM
