5.4L Starter Tries to Turn, But Engine Won’t Turn Over
97 E350 van with 5.4L - When I went to start it up after stopping a few minutes (at an auto parts store, no less), at first the engine turned over and it sounded like I let go of the key a little too soon before it actually fired up. When I retried, it wouldn’t turn over. It sounds like it has enough voltage to the starter, and the starter sounds like it’s engaging and trying to turn, but like something has the engine locked up and won’t turn. Ended up replacing the starter (partly as preventative measure, since this was the original starter with 257k miles on it, although the old starter tested good off the vehicle), but with the new starter it does the same thing.
I’m wondering if something electrical may have been fried by the failed initial start attempt. Or is there something mechanical with engine that could have gone haywire just at the wrong time. Any ideas?
No offense intended but your description of the symptoms isn’t helpful.
Your wording of the symptoms are describing your hypothetical conclusions. (“Sounds like it has enough voltage” )
Describe to us exactly what it does.
Is the engine rotating? Or is it just a click? How old is your battery? What condition are the terminals?
Took the belt off and it started right up. The AC compressor pulley feels locked up and all the other pulleys turn freely. So next question— can this be fixed by just replacing the AC clutch or would the whole compressor need to be replaced? (I’m not real familiar with work on ACs.)
. If it were just the pulley then the compressor would turn with the pulley
It's easy to check on the state of the compressor's internals to see if there is internal seizure. Just put a wrench or socket (8 or 10 mm, IIRC) on the bolt head on the clutch hub (it's attached to the compressor shaft) and see if the shaft will rotate or not. As long as the clutch hub is not jammed into the pulley, this will tell you what is going on.
93aero5star
General Automotive Discussion
05-24-2016 08:19 AM
spencercj
1983 - 2012 Ranger & B-Series
06-02-2003 08:25 PM
