Need help with steering coupler
I needed to replace the steering coupler on my 1970 F250. I was able to remove the collar bolt and one of the bolts connecting to the steering column. The other bolt would not come loose. I cut the bolt in half with an angle grinder but it still did not come out the other side. I tried cutting off the nut on the other side but ended up gouging the wavy disc the steering coupler bolts to and the bolt still didn't come out! What is that thing called? I see it in my shop manual but the doesn't have a name. Where can I order it and how do I replace it?
https://cimg0.ibsrv.net/gimg/www.for...829523da35.jpg
1969/74 F100/250 2WD & F350 with M/S & P/S; 1975 F100/250 2WD & F350 with M/S only.
No Ford dealer or obsolete parts vendor has any. AFAIK, it's not reproduced.
Dorman Products sold by auto parts stores has a replacement.
Pic: 3A525 is the coupler, the flange that the coupler bolts to...is made as part of the steering shaft (3524). Pic shows a different style flange than you describe.
I have the steering coupler (part 3A525). Its the upper flange I want to replace. So my choices are to replace the entire steering shaft (which will have a new flange on it?) or could I replace the upper flange with one of these?
https://www.performanceonline.com/Ra...r-RJC01-18878/
https://www.performanceonline.com/Bo...oupler-Deluxe/
This is a similar issue to what was going on in this thread:
https://www.ford-trucks.com/forums/1...ing-upper.html
Does your 1970 F250 have manual or power steering?
Summit has this listed as the replacement steering shaft. U-joints on both ends. I'll pull the steering column and decide which way to go.
https://www.summitracing.com/parts/brg-000970/overview/
The one product I listed looks like they put together custom flange / rag joint combos. Need to call them for more info....
Does your info have the shaft diameter and number of splines for both ends of rag joint?
1983F1503004x4
03-05-2013 11:57 AM
job1bf
01-10-2007 08:02 PM
MAX68
01-16-2006 04:05 PM
