Need help finding a part
1961/64 F100/250 with FX Cruise-O-Matic.
In addition to the above, GREEN SALES CO. in Cincinnati OH has 3 = 800-543-4959.
Shown as 7A216 in pic:
1964 Falcon Shift Detent
Found a shift detent that matched the one on the truck. This was the only place I could find one in stock with a web site ready to order, so I took a chance and ordered it. Felt pretty confident it'll work.
https://www.dearbornclassics.com/col...lane-1964.html
It will not!
It will not!
The one you need is for a 1961/64 F100/250 2WD w/FX Cruise-O-Matic.
Post #2: Chad gave you the applications/sources and Ford part number (C1TT-7A216-A) for the correct detent. I added further info in post #3.
So why in the hell would you assume a 1964 Fairlane detent would work?
And...besides the detent, the '64 Fairlane uses a different upper flange than 1961/64 F100/250 2WD
WRONG PART! This is for a 1964 Fairlane 289/C4, the Ford part number is: C4OZ-7A216-A
This is the one that came out of my truck.
I think they are the same part. I'll let you know if I'm wrong when it gets here.
The one you need is for a 1961/64 F100/250 2WD with FX Cruise-O-Matic (C1TT-7A216-A).
Since the part numbers are different, the one you bought is incorrect!
There's a gazillion different detents, all look similar, but that doesn't mean they are all the same.
The one you bought is for a 1964 Fairlane w/a 289/C4 (C4OZ-7A216-A). 1964 Falcon 260 V8 came with the 2 speed Ford-O-Matic.
