symptoms after trans flush
02' here so all I did was pull plug/pan, roughly 7qts. Installed new filter, 6.0 cooler and refilled the 7qts. Started truck and saw drain line filling up. A total of 11qts got pumped out into bucket and 11qts put in. So, I'm "even" with fluid.....well, she shifts good, but at idle it'll lunge, especially in 2,1..almost wants to stall. Put in park, check fluid level(while idling) and for life of me, can't tell what the reading I..im freaking out here, guys!
. Is these/this symptom result of low fluid?
It seems to be a bit hard to tell. I did mine a little bit ago. If you check it when its off, you can see what the dip stick looks like when its wet. I was driving around a bit over a quart low. I thinks it good now or a bit too high. Now I'm looking for 1/2" hose to install the magnifine filter.
I got mine from NAPA, I can get the numbers off it if you need them.
I’m just getting around to using YouTube for mechanical stuff.. don’t care about subscribers or whatever.. I’m having a hard time figuring it out myself and I’m 25!!
SixGunCaliforniaKid
12-03-2013 11:07 AM
