1989 Bronco rear seat
Old 01-18-2018, 08:52 PM
whisler's Avatar
whisler
whisler is offline
I need some info on 1989 Bronco rear seat. Are they at all similar to a standard cab bench seat, slide, tilt etc.? Or are they solid mounted with a solid back?
I need a new bench seat for my 1989 F 250 std. cab and found a nice Bronco rear seat in the right color for a great price on CR but don't know if it is even use-able.
Any info appreciated!
Old 01-18-2018, 08:59 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
they fold and are skinnier.
Old 01-18-2018, 09:21 PM
whisler's Avatar
whisler
whisler is offline
If you mean skinnier as in less padding in the seat bottom then that won't do. Or do you mean not as long, side to side?
Old 01-18-2018, 09:48 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
less width by quite a bit
Old 01-18-2018, 11:06 PM
whisler's Avatar
whisler
whisler is offline
Oh well, that won't work. Thanks for the info.
Old 01-18-2018, 11:24 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
probably look weird up front with all the extra space on sides
Old 01-18-2018, 11:30 PM
McLeod's Avatar
McLeod
McLeod is offline
They are spring loaded too and flip forward.
When folded, they tuck completely into the area behind the front seats and the ledge in the floor and kind of form a bulkhead.
(Just about every Bronco rear seat I have seen , the upholstery is unhooked at lower front edge and the torsion spring isn't installed correctly like in the above picture.)
ragtop69
03-10-2018 10:43 AM
BURNSTOUGHFORD
1978 - 1996 Big Bronco
03-18-2011 08:49 PM
TexasGuy001
12-20-2001 11:03 AM
bronco_jim
02-27-2000 04:24 AM
Quick Reply: 1989 Bronco rear seat
