EBPV outlet freeze plugs - give away
Since I have my turbo off I am also in the process of deleting my EBPV among other things. I already ordered and received the deleted pedestal and I removed the butterfly and plugged the hole in the housing with a 3/4 freeze plug. I ordered what I thought was two Melling 3/4 brass freeze plugs from autoplicity for 70 cents each plus shipping. Turns out, it was two 10 packs for 70 cents each. So now I have 19 freeze plugs...
I'm not sure if USPS will accept them in a letter size envelope but if anyone wants to give it a shot, send me a SASE and I will send you one free of charge(US only). Send me a message for my info.
I also sprayed the turbo housing with some VHT "Old Ford Blue".
Did you pre-heat the cast iron? I have a welder but my skills are low. I know many people that just use a freeze plug but I’d rather weld it up too.
At least the outlet can be removed fairly easy without removing the whole turbo if I needed to weld it later on.
https://www.ford-trucks.com/forums/1...-my-4r100.html
I took a bolt, ground the edges down so it was slightly round, dropped it in and welded it. No preheating or cooling, was on there 10k with no issues until i replaced with a new turbo and blank one.
F-250 Super Duty
02-21-2011 03:10 PM
Kwikkordead
05-25-2007 06:13 PM
