300 inline 6 head replacement
I'm no 6cyl. person but I think they all had hydraulic lifters. As far hardened seats I don't think you need those in an engine with only 8.4-1 compression. I have taken a bunch of old Ford engines apart and the only one I came across with serious seat recession was a 429 Cobra Jet that had been driven by teenagers putting the cheapest gas they could find in it. Even then I felt it was the 11.3-1 compression combined with cheap gas that caused the problem. If you feel you just got to have hard seats just take your head to the machine shop and have them rebuild it. I just got a set of 4 barrel Cleveland heads back from the machine shop where I had them install new seats, not because they had recessed but because three of them were cracked. It was only $120 for all eight exhaust seats.
I'm sure some of the 6cyl. guys will chime in on what will fit your block.
Idle it as slow as you can, lay a couple of shop rags across the top to keep the spatter down and it should be fine.
C-Leigh Racing
11-14-2008 11:01 AM
farmerboy
12-08-2006 06:40 AM
w951wxj
02-18-2005 08:17 AM
