sync 3 and ver 3 update
Received 6,675 Likes
on
Go to owner.ford.com and you can download the 2.3 update yourself. It's kind of complicated - some people make it even more complicated - but there are fairly decent instructions on the site. You'll need a USB drive that is 16 GB (it says you need 32 but I didn't).
If the dealer does it they'll probably leave your truck running for an hour. I didn't have to start mine at all. I simply turned it to accessory mode.
on
on
Just leave the USB drive in the port and eventually the system will finish updating regardless if it`s running or not.
If you`re going to leave your vehicle running, i`d kill two birds with one stone by letting the SYNC system update and at the same time, drive your vehicle to run a few errands.
Also after the update, don`t frustrate yourself again by putting that USB drive back in your computer to report back to Ford like the instructions say. Just make sure you have WiFi turned on in the SYNC system and it`ll send that updated info to Ford within an hour after a successful update or it might even take a few days.
Just be patient.
