92 f-150 wont start
92 f-150 wont start
Just got a 92 f-150 for $350, replaced everything it needed cleaned fuel tanks replaced both fuel pumps. The truck seems to have been running worse taking a while to start loping at idle when cold. About a week ago I started the truck and unplugged the iac while it was running and it stopped
right away. Plugged it back in and tried to start it would only fire once in a while wouldnt start. Both fuel pumps work, so could the filter be plugged and not letting enough fuel get to the rail? And also what could my idle problem be? When it ran it had a hunting idle and when you revved it it would almost stall go back up almost stall again and so on until it finally smoothed out. The engine light comes on once in a while when driving and goes off until the last time I drove it it stayed on until I shut it off. Havent had a chance to try reading the codes. Thanks for any help
Havent tuned it since I bought it because Ive been fixing all of the other peobkems like front end, fuel tanks, column, shocks, transmission ect. Do you think an msd distributor and coil plus msd wires and new plugs would do the trick?
I replaced the Iac and the pickup in the distributor and still nothing. Still wont fire on ether or gas and has the correct fuel pressure. Im stumped! Could it be the map or the maf? It also has strong spark.
Timbart1
03-10-2019 02:01 PM
